Adding to Cart…
The one with the cat leaping on your avatar is still my favorite, but they're all fun.
Meanie!!!! I'll have to sic the cat on to a spider ... ;)
There is a spike poking out of the right bracer.
Is there a way to fix this?
EDIT
It seems to originate from under the pocket
When I turn away the opacity down for the 2 needles on the outside, it vanishes.
There seems to be some problems with those needles.
Yes, you've found another reason why I went freebie instead of product. Turning off smoothing will fix that, or turning off the opacity.
Ah ok.
I've turned the opacity down for the needles so they are gone now :)
Found one small issue though I don't know if you'll want to fix it. For the bracers, the topmost buckle and strap are on the same material zone instead of being split.
Oh, and art. Just a test picture though.
EDIT: Bracers, not the boots
Thanks for pointing it out. If I get time I'll reupload.
Wow this is amazing. Teofa pointed me over here. Super glad she did too thank you!
