Even the Polygons
Hi,
I play a little bit with hexagon to creat a boot for G3F. I do not know if this is a problem but my polygones are a little bit out of shape. Is there a tool to make the polygons more even? Here are two pics from what I have done.
Yes, on the uv&paint tab, the smoothing brush.
Thank you. It work very well.
By the way, is there a tool were you can order the hole figure at once?
No not if you mean like the Smoothing brush does.
There are some Tool > utilities that come in very handy like the one to "weld all dots" ... good to use that one before starting the final uvmaps. Remember to "save" or "incre-save" often ;-)
Ok. Thank you
