Morphing Python Problem
Hi everyone.
Im new here and new to daz3d but getting use to it because I have been useing it for a month now but the one problem im having is the content that I bought which is Morphing Python.
I was wondering if somebody could help me because I am really stuck. I have searched google and the forums but found not much info.
Any way the problem I am having is sizing the morphing python, I found on the poseing and shaping area in daz3d the option to make the snake longer by useing the lengthbody option but the trouble is when I make the snake longer and I go and reposistion the figure distorts and messes up. I have tried lengthing it scaling wise but it dose the same thing. If I leave the size alone and posistion it its fine.
All so is there another way to pose a morph in to the current posistion of likeing without it moveing all over the place. I click the left mouse button and drag bits in to place but every thing else seems to me along with it.
Thanks any help would be great! I really want to get in to creating art but at the moment Im finding more problems than creating.
I can't find any 'lengthbody' option for the snake. What are you selecting in the Scene tab when you get this option?
Monty the Morphing Python should only be scaled Up or Down as a FULL scale never as longer, that breaks the bones.
To pose in place you need to use EACH section and the Parameters dials for that section.
Expand it all the way in the Scene Tab, each section can then be selected and then posed with the dials.
Tip: Half way down the axis flip so what was left will become right. You will know when you do it the first time.
I hope this helps.
I found the LengthenBody morph. Use the Lengthen morph first, then use the rest, it works OK for me. Have you read the Readme file that comes with it?
OPPS!! Never noticed the Morph before. I stand corrected. I have used it (Python) to my pleasure before. Here is the render.
