Rooms that come apart
There are some great room sets out there, but many of them are extremely difficult to use. Please could developers bear in mind that that it is really difficult to arrage and move items if the walls are in the way, even if they are made invisible they are still there and make manipulation very difficult and time consuming. It is also really useful to be able to mix and match parts of different sets. Please could you build so that each wall and ceiling can be either deleted or moved out of the way once loaded or else load as individual items. Some do, but many do not.
Yeah modular is key for versatility too, just like Jack Tomalin's products
You can make the room unselectable, so you can freely click through the invisible (or visible) walls to the contents. For an individual item just click the arrow icon next to the eye icon in the Scene pane, for multiple items select them all and use the Selectable button in the Parameters pane.
http://www.daz3d.com/shop/room-creator-version-2
Modular, and comes with a full tutorial.
There is also this set for asian rooms: http://www.daz3d.com/snapping-asian-interior-construction-kit
And if you use Poser there is also the Modular Living set (both basic and expansions) over at RDNA
