SG MechanEyes Question
retiretomaui
in The Commons
http://www.daz3d.com/sg-mechaneyes
Can this work with Genesis 2 and 3 characters? If so, do I still have to get the Victoria 4.2 Morphs that the page says is required? I'm mostly just doing Genesis 3, if that matters.
Thanks,
Bob
Not directly...at least for G3F. For Genesis and Genesis 2, if you have the V4 UV set it should easily work. But for G3F it would need at the least manual application (the eye UV set for G3F is close that previous generation textures mostly work without too much trouble).
They are also optimised for Poser so some tweaking of the surface settings is required for DS.
