Custom Tweener
TimBo
While making the videos used in my other post "Best fps rate for use on YouTube" I can not come up with a tweener setting to equate a rocket sled ride. On an Air Force plotting chart I noted the shape of the accel and decel curves created by the "Sonic Wind No. 1" rocket sled ride. Col. Stapp was very brave or crazy.
I have tried many different settings and have not yet found a single or combination of tweeners to even come close to an actual accel/decel plotting. I am beginning to think it can't be done with Carrara's tweener. Is there an external program or add-on whereby I can create a more complex tweener?
Post edited by TimBo on
Yup. I've posted this in your other thread:
Adjusting Amplitude, Timing and Scaling in the Graph Editor
(new in Carrara 8.5)
It basically gives us full control on how tweens behave.
Have you tried animating this as several seperate keyframed events inital excelleration,. full speed,. rapid deceleration
have you tried using forces ?
Carrara does physics,. you can use forces to push a "proxy" (low res "stand in" model ) along a track, or in a direction
the strength of forces can be animated over time (engine on / engine off) .
colliding with the water safety barrier iwould be a large negative force which rapidly deminishes.
I have several camera positions along the way and have some riding near the sled or pusher. I have a couple close-up halfway cameras to watch the vehicle whiz by. But I see what you are getting at. No, I haven't cut out "prime" events from a rendering and assembled them to make a video. Good point there. The forces idea is something a bit above my head so no I have not tried that.
Actually what i meant was,. animating the initial accelleration to full speed,.(bezier tweener) keyframe a section at a constant speed (linear tweener), then keyframe a scetion of a deceleration event (bezier tweener again),
broken down into sections it's easier to deal with each part to get the overall animation you want
Huh... I was thinking that he did that and was looking to tweak the results. Right, we need to get some keys in there so that we have some tweeners to tweak! ;)
