Where are the facial expressions on G2 female please?
Where are the expressions on G2 female? I have created a character using G2 female, I have head morphs installed. I went to look for facial expressions. When I had been working on a character previosuly, perhaps a V4-based one, I recall that when I clicked on the character, I had an expressions slider somewhere for "happy," even some sliders for mouth sounds, etc.
Thanks in advance for any advice :)
  • You know that thing where, once you posted the question in a forum, you suddenly find the answer? Well, I just found posing tab, pose controls. :)
  • MattymanxMattymanx Posts: 6,996
    edited January 2016
    Select the figure and then go to the Parameters Tab.
    On the left side at the bottom you should see "Pose Controls".  Expand that and look for "Head" and under that "Expressions"
    Those are the full expressions.  Everything under the head can be used to tweak her expression further as well.
    If you are looking to make her really smile, I highly recommend this - http://www.daz3d.com/smile-delight-for-genesis-2-female-s
    Post edited by Mattymanx on
  • OK, thanks so much Matty :D
