How to tell how much VRAM I am using
Widdershins Studio
Is there something in DS that will show this please ?
I haven't found it yet if it exists.
Many thanks.
Widdershins Studio
Many thanks.
There is nothing in DS that shows how much vram you are using
I monitor usage with GPU-z but you only know what its using once the scene is in the card & actually rendering
https://www.techpowerup.com/gpuz/
Great thanks, I'll give it a go.
I use this gadget in Win7, pretty acccurate for me and gives more info than just Vram %
Yes I used to use that one, but they dropped gadgets in 10 - there is a way to get them back with a mod though.
Thanks both
press "CTRL+SHIFT+ESC" and check "task monitor" CPU/MEMORY use
Many thanks.
There are several options, I use EVGA's Precision X (which works for any brand nividia gpu,) mainly because I am used to it, and I already used before I started toying with DAZ for modest OC and fan control. There is also MSI Afterburner as well. Both of these offer multiple skins and can be sized to fit your window.
