Light Bounding Box? What is it?
I've noticed that several content packages like rooms and building come with a "light bounding box".  It's like a shell built around my house.  I render in iray but don't know what it is.  Can someone explain what is its purpose?
  • Where are you seeing this?
  • TiddlyTiddly Posts: 34
    edited January 2016
    It's a black box "light bounding box" that came with a package.  It surrounds the house.  What is it's purpose?
    Post edited by Tiddly on
  • KindredArtsKindredArts Posts: 1,333
    I think it's for less complicated shadowing in 3dl. You can use a distant light, and just set the light blocker as a shadow caster. That would be my best guess.
    FFS, I just realized it says light blocking box.  I've been up too long.  Nevermind.
    Some others have it as 'black out' box.  It is something that will seal the 'room' except for the designated portals (doors/windows).  This will prevent light leaks at corners of walls/ceilings/floors and still allow removal of interior walls for 'long' shots without having to redo lighting.
