Solved, disregard.. Unable to use Morph Loader Pro on Genesis 3 Characters.
I have had success in the past with creating morphs for Genesis and Genesis 2 characater by exporting OBJ, modifing in Blender and then using Morph Loader Pro to import the morphs. I am unable to do with this Genesis 3. I always get a data does not match error. Anyone have guidance? Would really like to use the Gen 3 character for my project but I need to be able to alter their appearance in Blender.
Edit: The issue was that when importing in Blender on that comupter I had it set to Split the object into groups. Once I changed that to not split objects it worked. Sort of. Still having issue with the morph affecting things it shouldn't but that is a different problem haha.
Post edited by incendy_69d1d827b7 on
Workflow I am attemtping: Change resolution to base with 0 subdivsion mod. Export Genesis 3 Character as OBJ using the Poser Template. Open in Blender, adjust shape with sculpt brush, very minor adjustsments and same vertices count. Export as OBJ. In Daz select my character and start Morph Loader Pro. Choose my obj as the morph with the Poser Template, and click accept. And it fails with an error about the data does not match the mesh.
Since I am only modifying the head, I tried to just export the head and then in Morph Loader I tried to choose the head as the target, but still get the same error.
Are you sure you don't have dynamic sculpting activated as this does add vertices.
I am sure yes. I even tried just doing the adjustments in Edit Mode in Blender to make sure. But the count stays the same. I am just rotating the ears a little bit. And if I use a Genesis 2 or Genesis character it works. It is just with Genesis 3 that I get the error. Very odd.
