IS THERE AN AUTO-FIT?
dash2128dash2128 Posts: 736
I'M FINDING IT EXTREMELY DIFFICULT TO FIT 'A-3 SKY COMMAND DAEDALUS' UNIFORMS TO MY GENESIS CHARACTERS.  AFTER CONSIDERABLE EFFORT, SOME OF THE FIGURES HAVE ACCEPTED  AKO OR HIRO JACKETS, BUT OTHERS WILL NOT- YET THEY ARE ALL GENESIS.
IS THERE A PLUG-IN THAT WILL SOLVE MY PROBLEM, AND CONVERT THE UNIFORMS TO THE GENESIS FIGURES, EFFECTIVELY?
Post edited by dash2128 on
  • For Genesis there is http://www.daz3d.com/a3-and-h3-shapes-for-genesis . If you are wanting to use the items on Genesis 2 or 3 you could use that to AutoFit to Genesis, then save each item as a Figure asset (File>Save as>Suport Assets), then AutoFit that to Geensis 2 (or directly 3, if you have the Geensis clone for it).
  • dash2128dash2128 Posts: 736
    THANKS FOR THE TIP!
    I'm trying to find out how to make the process easier.
    Making sure I convert, using AKO-3 is important, I discovered.
    But I want to make it as easy as possible; I'm spending a long time just fixing the wardrobes that won't convert easily.
    330 x 373 - 85K
