Nails and Genesis 3 V7
Hi Everyone. How do I get coloured nails both finger and toe on to Genesis 3 and V7? Cheers
You have a couple of options. Some characters come with a material file to change the nail color. If you don't have any characters that have nail colors you can use a shader preset on them. If you look in freebies I am sure you can find some shaders to suit or you can purchase some. There are also a few nail products in the store.
Which ever you choose you select the character in the scene to apply. If your using a material file (one created just for nails) that is all you will need to do. If your using a shader preset then you need to make sure you also have the nail surface selected in the scene.
You can select the nails in surfaces; then change the colour as I did in the image.
The character had an Iray shader on, all I did was change the base colour: default in the top image (pink), to a nice bold red in the lower one.
