Glowing Eyes Iray Genesis 3 question on how to UNapply them
jakiblue
in The Commons
I applied one of the glowing eyes to my G3M character, and then after a bit, I decided I wanted him to have normal eyes. I applied the M7 eyes to him, but the glowing eyes didn't go away....how do you UNapply the glowing eyes effect?
Taking a wild guess here, because I don't have them, but I'm bettign they use the emissive channel. Look at your surface tab, and delete any maps in the emissive channel, and turn the color to flat black. That will turn off emission.
I suspect the issue is that the Glowing eyes presets use the Eye Moisture Surface for a number of it's settings and usually an eye preset material leave the channel empty so as not to change any reflection settings you have added to the eye. So changing to another eye setting is leaving the surface settings in place.
So to reset it back you will need to apply an eye reflection mat preset or base Eye Mositure mat preset that affects the Eye Moisture surface. I probably should of included a preset to reset the eye moisture back to base settings to make it easier to turn off.
Sorry about that.
Hope this helps :)
