how do you change the dmc file use for another lipsync
WendyLuvsCatzWendyLuvsCatz Posts: 40,291
edited February 2015 in Daz Studio Discussion
I made 3 DMC files for cerberus a 3 headed dog
http://youtu.be/1L0hSe30h5Y
they work fine in mimic lite and pro and mimic for carrara
but DAZ 32 bit lipsync only loads one and remembers it so I cannot do the other two heads separately loading and analyzing.
Mimic live just stops working
is there a temp file somewhere I can kill to do the other two?
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,291
    Nobody knows the answer I guess
    I will need to find where DAZ hides the temp file I suppose and doctor it in notepad.
    a new dmc analyzed should not overwrite keyframes as it uses morphs on another head, it is just a matter of getting lipsync to ask for it instead of apying the previous one.
    This is also a problem if you use the wrong dmc btw, it does not let you add a different one.
    I imagine not very many people use lipsync in DAZ or that would have been remedied long ago
    I know mimic live alows dmc replacement but sadly this figure freezes it.
    Certainly Poser talk designer can use a new file (I must try to make one for that too) and Carrara you can add another dmc.
    The alternative is to just export pz2 from mimic instead of using lipsync but I was kinda hoping I could create dmc files for others without mimic to use for lipsync since DAZ stopped selling it.
  • Did you find the answer?
  • Not for DAZ studio liosync
    I made 3 dmc files one for each head I can use in Carrara mimic plugin and mimic pro to create 3 pz2 poses for it
  • I see... I have problem with the Unshaven for Genesis Beard. The morph names are the same that you declared in your Genesis 2 dmc file, and it is still not working... I have wrote a more detailed comment here: http://www.daz3d.com/forums/discussion/comment/972212/
