Jared for Michael 7 Question
barbult
in The Commons
Does anyone have Jared for Michael 7 yet? Does he render as orange as he looks in the promo images? He's cheap at 75% off with purchase today, but the orange skin makes me hesitate.
In 3Delight he renders normal; with a fair, but not pale skin. I think the light in the promo pic is making him look orange, or maybe the ginger hair ('halo effect'). Jared is a nice character, but I'm going to change his chin. It is too poined for my taste, but this may be welcome for Elven/Fairy/Fantasy etc. renders. He has very nice eyebrows!
Uups, I quoted myself!
He looks fine to me, rendered with the default HDRI....
EDIT: He gets a pale skin when you render him in 4.9. I'm just waiting for that picture to complete rendering and will post it then. That has probably to do with one of the parameter settings that got fixed in 4.8 and influences how skin looks.
Rendered in 4.8
Renderd in 4.9
Thanks for the images BeeMKay
Can anyone say if the Jared for M7 Default Skin Clean Shaven has stubble showing?
I'm using G3 for hunting, tramping, camping scenes and want a more outdoorsy, unpampered look for females.
With Genesis I sometimes use appropriate male skins and this looks like it will work the same for G3 but even close stubble kills the effect.
I'm currently not seeing any discount on Jared (just plain $17.95). I notice Abandoned District doesn't either. Is this a store error?
Thank you! Fortunately there was a couple of sale things I wanted. $4.49—that's a bit better!
Yeah he does look orange. I wish promo art used more neutral lighting so I could see what textures look like
As was discussed in another thread, if the promo used any emission shaders, these by default load with a temperature that turns anything in the render orange.
Clearly, the temperature can be changed. What I am saying is, if someone double clicks on the Emissive shader in the DS default iRay shaders it loads with a temperature of 2900K, which has an orange color. This can then be changed, but if it is not, the render will go orange. Someone else mentioned that the orange skin color is probably down to other reasons, in the skin translucency settings, so this orange skin look can have a variety of causes. The thread is here:
http://www.daz3d.com/forums/discussion/67756/what-i-don-t-like-about-iray#latest
Thanks for the link, but I'm still not clear on this. There are examples above of the character being rendered in 4.8 and 4.9. The 4.9 render has a bluer tint, 4.8 more orange. I don't know if the OP used an emissive shader anywhere when doing those, but it is a documented fact that the behaviour of SSS in the iRay renderer is different between 4.8 and 4.9, with a cooler cast being given to skin tones in 4.8.
Or, is it the case that the DAZ developers have also changed the behaviour of the default emissive shader to have a higher default colour temperature? I'm confused about the two different explanations for this skin colour difference and I think it does need to be cleared up because, as I say, there are some people who are determined not to move to 4.9. I'm one of them.
I was only speculating about a possible explanation for the orange tint, but I believe it is a highly unlikely explanation in this case, which is more likely one of the other reasons given here, for the very facts that you stated (ie the differences in 4.8 and 4.9). I merely stated what would happen (as this happened to me), if someone makes a surface into a light by just selecting the Emissive Shader Preset available in the default presets. This loads at 2900K, and someone unaware of the effect would see their scene rendered more orange than expected. It is highly unlikely that the person who did these promos was unaware of this, if indeed they used emissive shaders at all.
Using 4.9 would not force you to use Daz Connect, if that is your reason for staying with 4.8. it would give you updated versions of both 3Delight and Iray, including a fix for the issue that causes Iray to crash with certain models using the CPU.
Here's a quick iray render using basic lights Daz 4.8, he's not orange;)
From the 4.9-thread, first post http://www.daz3d.com/forums/discussion/67115/daz-studio-pro-beta-version-4-9-0-54-release-candidate/p1:
"IA Iray related
Here's the parameter in question for Jared's skin:, which would explain why he looks more "bluish" in 4.9.
In general, if lighting isn't the issue, for materials designed for 4.9, try looking at the "Base Color Effect" toggle. If it's set to "Scatter and Transmit", try switching it to "Scatter Only" to see if that gives you something that looks better to you. I've been tinkering a bit, and it seems to pull down the orange/red effect without a strong blue shift.
I sadly couldn't get a non-orange image out of him in iray. I have 4.8 I decided to stop trying. I'm not really an expert at Iray, and used predone light sets. But most made him orange.
I did get a decent one in 3delight which wasn't orange.
Serene...I used out of the box iray lights too for the quick render.... the Club Noir Photometric Lights from Daz....
Club Noir lights seem to be heavily tinted environments. Perhaps you used one with a blue tint which counteracted the orange in the skin.
Could be barbult, I often go for neutral to blue tints;)
Iray in DS 4.9 RC with the Tint fix. Karen 7 behind him for reference. Scene was lit only with the sun and default tone mapping.
I don't have 4.9, either; I'm using 4.8. The shaders in 4.9 use "Scatter and Transmit"; the shaders in 4.8 frequently just use "Scatter Only". I'm doing a render now or I'd show what I mean.
That said, Jared seems to be particularly sensitive to the lighting that he's in. If it's got an even slightly yellow, pink or red tone, he goes to orange. White and blue tints do best.
Edited to add: His arm bend looks pretty strange, too. I don't know if that is inherited from G3M, M7 or is just Jared.
Edited again to add: This was rendered in DS 4.8 Iray.
Helooks great, actually! He reminds me of FWArt's style! :)
Well, G2 style, anyway. I've noticed his G3 textures don't have that same smooth, clean, matte look... :(
His specular is lacking, that's a large part of the difference between those two images.
