how do i do?
Hi,
i dressed the actress. I put the shirt and other cape but the mesh of shirt goes on the cloth. How do i do to do the shirt don't visible in this case?
Hi,
If the clothing is part of a set check to see if the are presets to hide or reshape layers, or if there are morphs in the clothing figures to adjust them for fitting.
Failing that, with each piece of clothing is there a Mesh Smoothing group showing in the Parameters pane? If there is, set the Collision object to the piece of clothing below the one selected. if there isn't go to Edit>Figure>Geometry>Apply Smoothing Modifier... and then once you have it set the Collision object to the next piece of clothing down. Note that adding a smoothing modifier will slow the interface down.
ok tnks, i will try
