Daz Studio 4.8 bug or corrupt file.
Hello there,
Got a serious problem with Ds4.8 that has just started happening. If I load G2F (or any G2F) into the scene window whenever I use the node selection tool all the torso and legs seem to become selected as one "part", the "head and neck" select as another, the "hands and chest" as a third part. Lastly the shoulders collars are one.
I tired reinstalling DS but it still does the same. Also Genesis and G2M act normal...
In the scene menu I can pose each part correctly but its severaly slowing my work down - please help!
Regards
Steve C
I think you may be using the Region Selection tool, not the Node Selection tool.
Nope that is what I thought! Swap G2m for G2F in the same scene and everything works - try to select G2F and it selects the grouped parts.
I'm at the moment downloading the G2F figure essentials in the hopes it will fix the problem
Hmm update.
Tried reloading all metadata - did not fix the problem.
I then downloaded the G2F figure essentials and replaced them over the top of the existing files.
Problem fixed. I can take a guess that its a data folder that got screwed but which one I do not know.
Steve C
Interesting, because I had a bug, right after I Ioaded a prop, on 4.8; and it wasn't easy to fix, I had to reinstall a few times, before it cleared up.
