How to create a white "mask" material in Daz
Hello,
I would like to create a material in Daz that when rendered with any lights or renderer the render produced is a flat white color without any glossiness or shadows or ambient occlusion.
I have attached the image with the closest I have gotten. As you can see there is still a shadow under the breasts and on the left side of the torso.
Is there any way to configure the material to reach the result that I described?
Thanks in advance!
  • Richard HaseltineRichard Haseltine Posts: 109,303
    edited December 2015
    Not to work in any engine, since Iray fakes reality and reality wouldn't allow such materials. Why not just use the alpha channel from the render and fill it? Or for Iray do a Material ID render using Canvasses (in the Advanced tab of Render Settings).
  • Thanks for the answer! I was able to do it with the 3Delight renderer
    1000 x 1000 - 167K
  • Useful info, on both counts. Thanks.
