Adding to Cart…
what workflow do you use?
Curious if anyone has done any benchmarks with iRay between the Titan and the 980 Series. I'm using a dual Titan in SLI Config, curious how the new 900 cards stack up.
Thanks!
I find the numbering really weird. The 980Ti is basically a Titan X with 6GB (and slightly fewer cores). The 980, while very good, is not on the same level as these two other cards. Then you look at the GTX 690 and it compares with the GTX 970 for much cheaper. AMD's naming convention is even worse since they rebrand stuff all the time.
If you're using SLI for Studio, you're not getting the benefit of both cards. Nvidia specifically says to not use SLI for Iray. Also, which Titan and which GTX980? There are several Titan versions and 2 GTX980 versions.
d
