Shaping problem
TauAlphaCTauAlphaC Posts: 84
edited December 2015 in New Users
I was shaping Michael 6 and got a bleed through.  What am I doing wrong?  When I back off on the shaping slider, it goes away.  Thank you for any help.
Post edited by Chohole on
  • dracorndracorn Posts: 2,353
    You can select the eyes individually and move them back with z translate. Extreme morphs will do this sometimes. I will have to adjust eyes after I do an elf morph. I have also had to adjust the jaw after using an expression morph. Keep in mind that zeroing out a pose will reverse this adjustment.
    Thank you for the help.  I will try that.
    From the image, it looks like you are applying Michael 6 morphs to Gianni. You will need to set the shape to Michael 6 (removing Gianni), then apply the morphs.
    Post edited by Male-M3dia on
  • From the image, it looks like you are applying Michael 6 morphs to Gianni. You will need to set the shape to Michael 6 (removing Gianni), then apply the morphs.
    Thank you, I will try what you suggest.
