Daz3D - Posing a character + build an Armor in Z-Brush
Hello
I'm looking for help regarding rigging.
Basically what I'd like to achieve is to create an armor in Zbrush for a nude character-posed in Daz3D. I followed a Tutorial on youtube for clothing, this is great because they can have distortion. But for raw armor ? I want to create all items separately and stick them onto the body. they need to look "real" so no distortion on them if I pose them. Does anyone got any tutorial or ressources regarding this ?
(Attachement) This is an example of what I'm looking to create :
Thanks
  • Well, you could model each piece as a sepaarte OBJ file then import it and parent it - props won't bend, and won't need any rigging, but you'd still need some kind of body suit for the mail. If this is a weight-mapped figure it would be possible to make each piece of solid armour move as a unit, but you'd probably need either custom morphs in the armour to cope with the bulges of bent bones or morphs or (for a Genesis figure) GeoGrats to hide parts of the figure (depending on whether you thought the armour would be moved by or would constrain the flesh).
  • Hey Richard,
    Thanks for the answers.
    Yes I'd like to model seperate OBJ file (shoulders, arms, etc)
    Where can I look to "parent" obj inside Daz ? I never did this
    Thanks !
    Antoine
  • Either drag and drop in the Scene pane or right-click on the item and select Change parent (or select the item and use the same command in the Scene pane option menu) - the new parent should be the bone the item is meant to move with.
  • Also keep in mind that you want to use a lower polycount that what a piece like the one you're showing would have.  That level would be mainly for making normals/bump/displacement and textures to apply to a lower poly model in Studio. (Daz is the company name).
