Trouble with GenX 2 (Error creating morph from clone.)
I just reinstalled a lot of my library after a system crash and I'm now having trouble with GenX 2 - The problem is transferring a morph from G2M to G2F... strangely enough it works the other way around with morphs able to be transferred from G2F to G2M but at the moment I can't transfer any morphs from Male to Female.
GenX - Transferring morphs.
Loading target figure ...
Loading figure ...
C:/Users/Public/Documents/My DAZ 3D Library/data/DAZ 3D/Genesis 2/Female/Genesis2Female.dsf
Creating clone morph ...
I also have this come up when I load the male source....
GenX - Loading figure: Genesis 2 Male
Loading figure ...
C:/Users/Public/Documents/My DAZ 3D Library/data/DAZ 3D/Genesis 2/Male/Genesis2Male.dsf
Loading morphs ...
Analyzing dependencies ...
Multiplied formula with more than one mult/add.
Did you get this resolved? I am running into the exact same problem.
Ditto for me (I'm transferring my morphs from V4 to G2F). Has anyone else encountered this problem? I've tried every known resort—re-installing Daz, re-installing the plug-in, even attempting a System Restore to the last time it worked. All have failed. HELP!!!
Not sure if this has been addressed elsewhere.. but I was getting the same error. This is what I did to resolve the issue. Make sure DazStudio is closed. Then re-install Genesis and Genesis2 Starter Essentials. Both are required for G2 as I tried to reinstall Gen2 first and still received the error. I then installed G1 starter essentials and problem was resolved.
I am also having an "Error creating morph from clone" problem in GenX2. I have already written about it in two other threads, so I'll just put links here for the details of my problem.
http://direct.daz3d.com/forums/discussion/38334/new-release-genesis-generation-x2-upgrade-ends-soon-commercial/p8
http://direct.daz3d.com/forums/discussion/66609/stratus-mccleod-assembled-on-genesis-2-male-figure#latest
You can ignore my last post, Dimension3D told me how to fix my problem.
Great - but so many users have this error and no one is sharing the fix?
Sure, I'll share the fix.
---This was my problem---
I am having some difficulties with using GenX2 to transfer a Hiro 3 (H3) morph to Genesis 2 Male (G2M). The morph that I am trying to transfer to G2M is INJ-Head file -- !_Stratus_INJ.pz2 -- for Stratus McCleod.
This is what I have been doing on GenX's Transfer tab:
1) I click the Load Figure button and select the Hiro 3.cr2 file.
2) From Content Library I drag the INJ-Head file -- !_Stratus_INJ.pz2 -- for Stratus McCleod into GenX's Morph list.
3) I click the Select button, and pick Transfer: For All Non-Zero Values.
4) I make these selections for these drop down lists,
Mode: Create single morph
Shape: Hiro 3 -- There is another button to the right of this drop down list. On that button I pick Smooth.
Target: Genesis 2 Male
5) I click the Transfer button, and then a small window gives me those two error messages.
Note -- There are some other options below left on their original settings. They are
Limits: -10 to 10
Resolution: 50
The following checkboxes are checked: "Compress generated files", "Transfer controlled transforms", and "Transfer dial groups"
The following drop down lists are set to: "Ignore conditional morphs", and "Replace existing files".
When I click the transfer button, GenX2 give me two error messages, "Error loading clone morph" and "Error creating morph from clone."
Just to let you know, I have these products:
Genesis Generation X2
GenX2 AddOn for Genesis 2
GenX AddOn Gen3 for A3 and H3
A3 and H3 Shapes for Genesis
---And now here's the fix that Dimension3D told me---
The error messages indicate that GenX is not able to locate the H3 morph file for Genesis:
..\data\DAZ 3D\Genesis\Base\Morphs\DAZ 3D\Hiro 3\CloneHiro3.dsf
Because there are no gen3 clone morphs for Genesis 2, the clone morphs for Genesis are used. Do you have Genesis 1 installed? If so, please check that you have only one installation for Genesis (i.e. there is only one \data\DAZ 3D\Genesis\Base folder in all your content folders) and that it contains the H3 clone morph at the correct folder.
I found an extra copy of Genesis 1 installed in my computer. After deleting it, I was able to use GenX to transfer the Hiro 3 "Stratus McCleod" head morph to Genesis 2 Male.
