My G3F no longer looks the same
this is something I noticed. I'm sure she does not look like the same G3F I started with, I looked in hidden to see if anything there is used, nothing showing, I have uninstalled and reinstalled, but the G3F I load does not look like the G3F in the image of G3F or the G3F I remembered.
This new G3F is shorter, wider, and has bigger breast. And I'm sure G3F does not start with Nipples, but this one does
how can I get the Base G3F back ? . . I don't know if I did something inadvertently to have changed her, but I want the G3F back
appreciate any help, thank you
Start out all the installed morphs...one of them is set to 'on'. It should show up when 'Show Hidden' is checked but not all of them are showing for some reason. It's probably not one of the store ones...
when you say set to "ON" where should I be looking ?
I thought I could had figured something like that and find it myself, but couldn't. Not sure where I should be looking, everything is at 0 in Hidden
Usually that means set to 1.0 (if not using percentages...100, if percentages are set on). But it could really be any non-zero value.
If you have "Show Hidden" turned on for the Parameters tab, then it should show up there. Try using the Currently Used option.
yeah did all that. always had 'Show Hidden' , I doubled checked to make sure. Also nothing showing in 'Currently used'
maybe there is nothing wrong, and just recalling wrongly, and this was a mistake
I just finished with just scaling,(don't have any morphs for G3F) and every thing worked out like I was wanting, like there was nothng wrong, maybe I'm losing it. and G3F is normal
any ways thanks for the help
Have you installed the updated (since G3M came out) G3F?
Mine does not have the nipples on...but I haven't installed the update, so if you have that isn't a 100% reliable comparison.
opps . . forgot to update the nipple, it was from a morph dial , Actually an injection, was able to dial back to 0. what it was I don;t have V7, and V7 was one of the requirements, so the only thing that happen was nipples were added, no where else did the body changed. So there was no nipples, it was a mistake on my part
I figured that one out, forgot to mention that . . my bad
yes I did download the update, was hoping that would had fixed what I believe was wrong, first used DIM saw no change, so did uninstall then a manual download and installed, still no change .. I'm beginning to think there is nothing wrong, I'm just mistaken how G3F looked liked, I just don't recall the wider hips and belly and the larger Breast.
the only reference I have are the poses, the wider hips and belly are noticeable, but I could just have the wrong camera angle.
