Extending Aniblocks?
DekeDeke Posts: 1,636
In the past in Daz 4.8 I could click on an aniblock...like a walk cycle...and drag it out to extend it.  Lately I can't.  It doesnt' give me that option. I have to drag and drop multiple blocks into the timeline individually. What am I doing wrong here?
  • bighbigh Posts: 8,147
    I click it - them i can drag it
    So it work fine for me .
    It works for me too.      After I single click on an Aniblock in the Animate2 Timeline, it changes from Blue to grey colour, and says 'Double Click for Keyframes'.   I can then use the arrow at the right hand side to extend the aniblock to where I want it.
  • It depends. If you are at the end of the animation of an aniblock, then of course the aniblock won't extend. But if you not at the end, and you didn't crop the aniblock, then it will extend. If then you crop that particular aniblock, it won't extend anymore.
    858 x 316 - 18K
  • DekeDeke Posts: 1,636
    I do the clicking but when I try to drag on the arrow it says that feature is disabled.  Is there a magic hidden button I'm not pushing?
  • If you have Animate 2, it shouln't be disabled. If you have only Animate Lite, then you should upgrade.
    That was the. I have A2, but for some reason it isn't loading.  I see it in the Tools menu, but only AL in the timeline. I'll poke around and see if I can't get it running again.
    Experiencing same issue. Have Animate 2 but can only see aniMate lite and cannot extend aniblock. Did you figure out the issue? Using Daz 4.15
  • If you purchased Animate2  is has a serial number that get added in the field to ACTIVATE  in DazStudio
