Rearranging Studio
lx_2807502
I've been meaning to ask these for ages, but somehow never got around to it.
1. By default, Studio has a top left pane, and a bottom left pane, each with their own tabs. If you merge them, there doesn't seem to be a way to make a new pane/tab section again short of resetting the entire workspace to the default, which isn't the layout I'm trying to make anyway. Is there a way to do this? (let's say for example you want Content Library | Scene | Viewport | Surfacesetc all side by side across your screen, all in their separate tab groups to be visible at the same time.)
[TLDR How do I create a Tab Section that's part of the main window, not a floater.]
2. Sometimes (esp. in the Actor section) Morphs display as big boxes that have smaller, vertical sliders and waste a ton of space. Is there a way to make them not do that?
3. Is there a way to save a morph to always apply globally (in this case Eye Cornea Bulge to 1) ? I'm pretty sure I can set it for one character via saving the new morph preset or fiddling around with the ever confusing EFC freeze, but would I have to do it for every single base I have, or is there a way to just do it once?
1. With the pane floating, drag it by the frame (not the tab) until it is roughly where you want it - once correctly placed a bar of the highlight colour should appear in the slot it will occupy. Drop the pane and it should dock as a new group. If this isn't working make sure that Window>Workspace>Lock Docking/Undicking isn't checked.
2. I can't remember
3. Change the default value in Parameter Settings (the gear icon on the slider), without changing anything else in the figure, and then File>Save as>Support Assets>Save Modified Assets. Do remember, however, that a product update will overwrite your changes.
Oh, that works perfectly. I was dragging by the tab thinking the borders just resized: missed the inbetwen that gives you the fourway arrow.
Thank you!
