I can't get Dwarf Creator to show up in Poser 10
Barbara1337
I can get Genesis 2 male just fine, but Dwarf Creator doesn't show up no matter what I do. I've tried manuel and the Install Manager, nothing happens.
Any help will be appreciated.
Thank you,
Is in in the Content Library pane, DAZ Studio Formats>My DAZ 3D Library>People>Genesis 2 Male>Shapes>smay>Dwarf_Creator ?
This is where I found these
G:\Content DAZ 4.7\DAZ Content My Library\Data\DAZ 3D\Genesis 2\Male\Morphs
G:\Content DAZ 4.7\DAZ Content My Library\People\Genesis 2 Male\Shapes
OK, I located this
G:\Content DAZ 4.7\DAZ Content My Library\People\Genesis 2 Male\Shapes\smay\Dwarf_Creator
Let me put this on hold. I think with the path you showed me I can work from that. Thank you very much.
Barbara
Checking the actual file location in the libraries (at least for content installed with DIM or by manually unpacking zips) is a baseline check - if the files don't show there then something is definitely agley, if they do then problems with Smart Content or Categories can be worked around (and reproted as bugs if need be).
I've got it working in DAZ 4.7 , so I know that part is pretty good, I can load Genesis 2 male in Poser but still no dwarf. But it doesn't seem to be as far apart as it was. At least I have a starting point now.
Thank you,
Barbara
Make sure that the folder the dwarf set is installed to is also a Poser library folder.
I'm being dense again. When I install the dwarf set to the Poser library folder is this gonna be in Poser or Daz? Right now, I'm able to dial him in and change his face with dials. Not easy like DAZ but workable.
Thank you,
Ah, I see - I misunderstood the issue. The product doesn't have PoserCFs (Poser Companion Files), just the DSON Core files for Daz Studio. You could try creating your own in DS, but it may be simpler to use Dimensio3D's script to launch the importer in Poser by selecting a file via a standard fiel dialogue. It's possible, however, thats ome features may simply not work in Poser. The script is here http://d3d.sesseler.de/index.php?software=poserpython&product=dson_loader
No, you didn't misunderstand. I thought I would be able to see the little heads and click on them to make the different faces. Leilana told me it was in the dials. I think it's just gonna be one of these things that I will eventually get worked out. He's such a cute little guy, and for me Poser is easier.
I thank you for all your help, I know it takes away from your free time.
Anyway, I'll check into the script and also Poser Companion Files. Not gonna give up.
Uhm ... load Genesis2Male, go to the Parameters tab and look there ... as there are only morphs in the product, they should show up when installed correctly.
