Little white balls and cubes around clothing? oh... bones... but...
Hi - very sorry if this has been answered (I just can't seem to find anything in the forum). I'm new and I have this lab coat that was made for v4 that I've put on Genesis (male). In my screen cap you see the white balls and cubes around the bottom? (just figured out they are bones) When I put the lab coat on v4 I have the ability to select the cube/ball and turn it off. But on Genesis I can't select it.
Oh. ok... I just read the FAQ that came with it and it says:
** 6 extra bones with body handles are provided in the Lab Coat in order to pose the lower half of the lab coat."
Now my question is: since it's on Genesis does that mean I cannot turn off the "bones".  It shows up in my render, and that's no good. :(
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,175
    edited November 2015
    they probably have a separate surface you can turn the opacity down on or you can select and hide (edit delete if you wish) using the geometry editor.
  • Well, yes, hiding the surface with the geometry tool seems to work. Thanks!
