Adding to Cart…
When you click convert do you see a little figure posing bottom left of script? It should be emulating all poses being converted. Also the duf files are saved in the same pose set you chose. Did you check in there to see if the duf files are indeed there? I just did a test and it is working on my side.
Ok after you selected a pose folder, does the poses populate in the script before you have to convert?
What format is that pose set saved in?
That tab is to convert any pose files that are of type .ds to .duf so that Pose Builder can process them. If there are no .ds files in the selected folder then nothing will show in the list. My guess is that the files in that folder are .duf files and don't need to be converted.
Yes I was going to ask if you select upper body in the script, and go to that pose set, does it allow you to load the pose into that section?
i give up
Can you send a screenshot of the pose directory in explorer so we can see all the icons and files?
What product is this? I may be able to take a look at the files and see what the issue may be.
Go to the folder where the pose is located in your OS browser, and take a screenshot so we can see all the files in that pose folder.
In windows..Open in like your browser and printscreen.
Yes. We want to see what all is in that pose folder.
they say .duf but pose builder says they are not. However this is with any of the poses.
How about V4 Pose Converter for Genesis and Genesis 2 Female? Does that work can i switch products?
We will look into this. At the moment we are puzzled.
When you say that, do you mean that ALL of your poses are doing this? Like Basic Female, Basic Male, M5 General Poses.... etc.
I am trying to convert the Polish Workshop Assault rifle poses for G2 male to G3 male. Because they are preset_hierarchical_pose dufs they will convert, but will not load for the G3 male figures.
Anyone figured out how to do this ?
THX!
I've tried to load .duf file but .duf files are not selectable. What shall I do?
Try selecting the .png files. I'm not familiar with Macs, but with Windows you would normally see the .png icon and would select that file.
Will the converter work with G3M as well?
In theory yes. If converted G2M poses work on G3F, they will work on G3M as well, since G3M and G3F can use the same G3 poses regardless of gender.
