Reptilian 6 HD - editing legs to work with standard poses?
EternalWinds
Hey,
I assume this is a fairly easy "yes" or "no" answer, but when applying a full Genesis 2 pose to the Reptilian 6 legs, everything below the knee is ignored from the original pose. Is there some way I can fiddle with the bones to cause a pose to apply to the legs, too?
I've tried renaming the regions from things like "rFootCC" to simply "rFoot", but it doesn't seem to make a difference. It's not a huge problem, it's just tiresome to have to pose everything below the knee every time I use poses i've made, and i'm kinda hoping it's possible to make poses also apply to the Reptilian 6 legs... :)
No, you would need a hierarchical pose preset to affect both the base figure and the legs. Chenging the bone labels won't allow you to apply a pose to the reptile legs, changing the actual bone names would but the results would be sub-optimal due to the different starting positions (the pose just sets how many degrees to rotate each boen from the zero position).
