How to avoid "Goggles Hair"?
ImagoImago Posts: 5,692
Hi everyone!
Probably someone asked this before, but the search gave me no result... So I ask!
There's a way to avoid "Goggles Hair" when using the autofit? I posted a picture of what I mean.
The hair used are "Basic Hair for Genesis 2 Male" and the figure is Genesis 1 with Taiga morph applied at 100%
The hair look ok when I fit them to the unmorphed figure, but when I add the morphs, the hair make those awful "bubbles" around eyes and the strands moves up and down when I make the eye close and open...
Some workaround?
Post edited by Imago on
    You need to select the hair in the Scene pane, then go to the Parameters pane and look at Currently Used for the Hair.   Dial any morphs that you don;t want down to Zero, and taht should help.
  • ImagoImago Posts: 5,692
    Nope... It doesn't work...
    1280 x 720 - 140K
  • KeryaKerya Posts: 10,943
    I think it is the effect of the lashes - same like elf ears and autofollow:
    http://www.daz3d.com/forums/discussion/comment/230800/#Comment_230800
    edited November 2015
    I'll try the solutions in that thread and make you know if it works, thanks!
    Nothing to do... None of those methods worked for me!
    *EDIT*
    It worked, at last! It looks like I skipped, somehow, one of the basic steps!
    Now the hair looks good and doesnt's deform when I close char's eyes!
    Thanks everyone!
    Hooray!
