bLooper - Free Script to Loop Your Looping Animations (improved)
That's one of my oldest scripts
i added a Help and a WebHelp button.
The script now saves the settings when you close it, so next time ( often a few seconds later ) your settings are the same !
( yeah i know you know what settings are, i was just saying it for the others )
and there's a button to restore the "factory settings"
Say you animated a 30-frames dance cycle
bLooper can take the whole figure animation, or a selected limb, or objects/props
and repeat the 30-frames animation as many time as you want, one after the other
The Manual and package Download page : https://sites.google.com/site/mcasualsdazscripts/blooper-for-d-s2-and-d-s3
Post edited by mCasual on
come to think of it i only tested it in DS3 ... but .... testing in DS4 .... now ...
i didnt really start using Genesis 3 and discovered right now that mcjAutoLimb2014
the indispensible tool for animation is not working for her
but also just now, i saw that the fix is quite simple! ... then again ...
expect an mcjAutoLimb2014 update soon ( actually its not that simple a fix ... apparently )
but for bLooper ... it seems to work fine in DS4.8 and on Genesis3
as i understand this it copies whole frames
can you also delete whole frames with it ?
for that, not too long ago i made the mcjRepeatAction script
it can delete frames over a time range ( as long as keyframes are not between frames ))
and a whole lot of other operations
The script which can be found here
https://sites.google.com/site/mcasualsdazscripts4/mcjrepeataction
The Forum discussion can be found here
http://www.daz3d.com/forums/discussion/46584/mcjrepeataction-repeat-actions-over-a-range-of-frames
oh my
i use this alot for setting to ground but forgot it can delete whole frames
dz delete ok i see
