Sachra´s tail and clothing
chrbou2001
What could i do to make clothing like Hongyu´s bikini bottom fitting to Sachra´s tail? The back part should move a little bit down to make room for the tail (in the "Something wicked" outfit is a morph for this).
If the fit on G3F is good you could try adding a Smoothing modifier (if there isn't one) and set it to collide with the tail, or create a Geometry Shell (if there isn't one already) and collide with that.
Sorry, didn´t work but meanwhile i got a morph.
