Genesis 3 UV Swap
Hi @Slosh,
I apologize if this has been addressed elsewhere. I purchased the G3 UV Swap hoping I could figure it out without to much trial and error. I tested it by using one of my favorite textures by Chevybabe25 (Amisi). I applied the corresponding base textures to G3M and then applied the UV Female Preset. Attached is what I got.
Now I don't mind photoshopping out the seams and I can correct the "girlie" fingernails with post-work, however would this be what I need to expect if I choose to swap textures from male to female? I did dial in some "Dash" and "Aiden" to the base after swapping so maybe that's why the image appears the way it does. Any insight would be helpful. Thank you.
Trish
Test Render of Texture Swap
  • If you apply Amisi to G3F, select one of the skin surfaces and look in the Surfaces pane which UV set is used? Morphs don't affect the way textures apply, though they may of course cause stretching.
    Hi Richard,
    I did as you instructed and it says "Base Female." Thank you.
    Trish
  • SloshSlosh Posts: 2,391
    Interesting.  Even without applying the female uv swap, my Amisi's head doesn't look like that.  Here is what Imget for Amisi's texture after applying the ups to G3M.  Is there a chance you applied the base male ups here instead of the base female?  That's the only thing I can think of.
    640 x 849 - 320K
    Thank you for your response--and that G3M looks good wearing Amisi smiley! I'm going to "nuke" my current file and start over. It shows that I'm using the "base female" but I can try again. I'll let you know.
    Trish
    yes, please do... any anomolies like this would be good to know about
    Hi @Slosh,
    After redoing the whole thing, I didn't get the weird seams and/or striping. Not sure what I did differently or if it was just a weird anomaly. Once again, thank you for your quick response.
    Trish
    Test render of G3M with Amisi Texture
  • caravellecaravelle Posts: 2,698
    I found that the Genesis 3 UV Swap works very well; it is BIG fun and opens a lot of possibilities. Thanks, Slosh!
    I'm happy it's working for you now, Trish.
    @caravelle, thanks for the thanks cheeky
  • DkgooseDkgoose Posts: 1,451
    Awesome Stormlyght Amisi looks good on him.
