Genesis 3 Male
Daniel Barnett
in The Commons
I did a search for Genesis 3 Male and no model came up. Is there a Genesis 3 Male?
dbb
If you have downloaded any updates with DIM since yesterday, then Genesis 3 essentials will have been loaded into DS. If not, check for updates. Yesterday was the release of Michael 7 which is on the new Genesis 3 male base. The G3 male base is free and part of your updates. No morphs or anything. Those are now up in the shop as they were released yesterday as well.
I'll do that! Thank you!!
dbb
That was it! Do you know how well M4 items fit to Gen 3 male?
dbb
Thanks again!
The gen3 male base is included in the essentials pack, try the outfits on the base male (I haven't had a chance to yet!) I'm hoping the will be a g3m wear them all product like there is for g3f.
They probably don't yet. The only autofit clone that ships with the figure is the one for G2M (unless there's one for G3F as well, G3F Starter essentials was updated to add a clone for G3M). There should be add-on packs available before too long if it goes anything like the way it did for G3F.
Autoft any M4 items to GM2, then save as a figure and then you can autofit it to GM3. I did this with GF3 when she first came out.
Thans! I'll give it a try.
I run the latest update for Windows 10 and I'm having a few problems but will try your suggestion as soon as I finish checking into update problems.
dbb
You can also create your own M4 morph to auto fit directly from M4 to G3M. There are a few tutorials in this forum that explain how to do this. (The explanations are about getting clones onto G3F, but the technique for G3M is the same)
Thanks! It's great to know that it should work as it does to G3F!
dbb
