Long standalone staircase
Hera
in The Commons
Hello!
Is there anywhere I can find a long staircase like this, a stand-alone one. (It doesn't really have to be as long as that, as long as I can put together several sections.
I think this might have what you're looking for:
http://www.runtimedna.com/The-New-World-Vol.-3-Pre-Columbian.html
Hope it helps. :)
Standalone, just the stairs; so you should be able to easily join sections. It's in obj format which can be imported into DS.
http://www.turbosquid.com/3d-models/3d-stairs-model/344701
Maclean has a set of stairs prop which you could easily stack in Interiors Corridors. The rails and walls are separate material surfaces, so you could hide those, if needed
I've used Stonemason's modular-ruins to build a long staircase. If you want a nice neat staircase it should also be relatively simple to do it with primitives and then apply some suitable shader to them.
Interesting
You can just build one with cube primitives too
if just using DAZ studio
just load, scale save as prop re-add transform save as prop keep going
