can anyone have a go at doing this expression for V4?
I been trying for ages to get this pout expression (pictured in the Pamela Anderson image) for V4 but am really have no luck. I cannot get it looking anywhere like how she looks and I need this exact expression to complete a sexy Daz artwork I am in the middle of but I just cannot get this lips pout.
I am also aware of the expression packs avaliable as I have looked at many and cannot find any that match what I am after.
Does anyone here want to have a go at tryng to do this lip pout expression for V4? I am hoping someone else will have luck with it. It seems to be solely the lips that have any emotion in her facial expression so its only a case of doing those.
  • j cadej cade Posts: 2,310
    Not for V4, but I think this comes close
    Sorry couldn't help it
  • RuphussRuphuss Posts: 2,631
    haha so funny
    you have to have the exactly same shaped lips and face to get it to 100%
    this does not look bad i think
    834 x 1080 - 2M
  • JUJUJUJU Posts: 1,132
    I bet there are expressions like this....
    for example
    https://www.renderosity.com/mod/bcs/i13-gold-expressions-for-v4/91107/
    search for expressions v4 and I think you will find one ;)
  • SixDsSixDs Posts: 2,384
    Well, I gave it a whirl. As Rhuphus says, it won't look exactly the same unless the face morph is also the same, and your lighting and shadow settings will also affect the results.
    1200 x 1212 - 596K
  • MattymanxMattymanx Posts: 6,997
    It would depend on what Daz character packs you have installed for V4.  If you have Aiko4, Girl4 and a few others installed along with the head morphs you should have no issue getting it to look the same.  However, I have found that when it comes to expressions that subtle mixing of multiple morphs is far more effective then depending on one single expession morph.
  • I think you will need to puff p the lips a bit more than you are expecting to get the result. Also, do not underestimate the effect that the long bangs are having on the eyes. The hair is casting shadows that are not present in the two sample renders that were shown to you (nice work on both, by the way). This is enhanced by the angle of the head -- note how Pamela's face is pointing slightly down.
    Good luck.
  • SlimerJSpudSlimerJSpud Posts: 1,456
    On V4, IIRC, there's Pucker, Pucker wide, and Mouth Wide, or something like that. The Viseme for 'U' might help. Some mix of percentages on these will get you close.
  • But there is a morph "Playmate 90 for Victoria 4" ??
    this disappeared air...
  • I've never gotten a good likeness of someone/anyone dispite years of tryuing with v4. Getting a good likeness can be done witness Fygonatic's "Vulcan Pinup" on DeviantArt which is a good likeness of T'pol on Star Trek Enterprise (aka Jolene Blalock in amkup), but judging by the shoulders its  probably not V4. Like I said I have spent years trying to use V4 but the Daz3d characters just just don't seem to be flexible enough, and remember that human faces are not actually symmetrical. I would try Zbrush maybe Iclone if you can afford them, If you can make native V4 work, more power to you and you might let me know how you did it.
    Good Luck
