Genesis Mats to fit G2
Hello,
I thight it was simply a question of changing the UV setting, but none seem to work.
How is it done please?
Hello,
I can use V5 textures on Genesis 3 Female by switching UV Set to V5 What is the UV set of the Genesis one, and what UV sets do you have available for G3?
Hello & thanks for your reply,
I am specifically interested in using Genesis Mats on Genesis 2 figure. I have tried each UV setting in turn, but there are gaps each time.
Both Genesis and the Genesis 2s have several UV map options, it is a matter of making sure you have and are using the right ones.
