Genesis 3 male base ?
timsw6
in The Commons
I've just bought M7 and it will not work as yet cannot locate Genesis 3 male base in products list?
Mine was in DIM together with an update for Genesis 3 Female.
It's all part of Genesis 3 Starter Essentials.
thanks - found!
I still can't find him. Looked in all usual folders. Why can't G3M have his own cathegory same as G3F has? -.-
And yes, I've updated G3F starter essentials. Do you need to buy M7 to have G3M?
Yes it is in the DIM. Finally, it is raining MEN!!!!
Got this linkie, no purchase needed : 3
https://www.daz3d.com/downloader/customer/files#prod_21630
The male upgrade was a bit hidden amongst other installer files I had. It's not even highlighted as the female starter was.
G3M is a free bundle the same as the rest, your do NOT need M7 to use or install it.
You should have an entry in the Ready to Download tab in DIM for 'Genesis 3 Male Starter Essentials' as well as an update for G3F, did you install the new Male version?
If so, you should find it in the same place as G3F, under My DAZ 3D Library > People > Genesis 3 Male, so he does have his own category, is that what you mean?
Jimmy, read my own response : )
You must have replied Zakarosh while I was still laboriously typing, gald it's sorted anyway
I still got the pro bundle to get all the discounts on the new outfits and colorful skin (no more monchrome!) and hairs!
Important - I had to hunt for quite a while as well. Good catch.
