Transfer Utility Issue
Been having issues with conforming Marvelous Designer wardrobe to my G9 figure. The imported OBJ loads properly (image 1), but when I run the utility, it "shrinks" the OBJ too tightly, exposing skin (image 2).
Any ideas would be much appreciated.
if you don't make the clothes around the base shape then you need to use the Reverse Source Shape from Target option in Transfer Utility.
i.e. choose Current Shape in TU > Source > Item Shape, then tick the option Reverse Source Shape from Target.
Be noted, the best way is to always make wearables on a Base figure rather than characters...
