Transfer Utility Issue
Been having issues with conforming Marvelous Designer wardrobe to my G9 figure. The imported OBJ loads properly (image 1), but when I run the utility, it "shrinks" the OBJ too tightly, exposing skin (image 2).
Any ideas would be much appreciated.
  • Richard HaseltineRichard Haseltine Posts: 109,650
    if you don't make the clothes around the base shape then you need to use the Reverse Source Shape from Target option in Transfer Utility.
  • crosswindcrosswind Posts: 9,751
    i.e. choose Current Shape in TU > Source > Item Shape, then tick the option Reverse Source Shape from Target.
    Be noted, the best way is to always make wearables on a Base figure rather than characters...
    527 x 794 - 64K
