MDL color value is ignored in shader mixer?
kitakoredaz
Post edited by kitakoredaz on
kitakoredaz
The usual syntax is
I'm not sure if the behavior is different using the syntax you have, but you might give it a try.
In addition, if you use annotations (the anno:: syntax you see in the DAZ provided MDL shaders), Shader Mixer will "do the right thing" when you wire it up.
