MDL color value is ignored in shader mixer?
kitakoredazkitakoredaz Posts: 3,526
edited August 2017 in Daz Studio Discussion
smiley
Post edited by kitakoredaz on
  • EsemwyEsemwy Posts: 578
    The usual syntax is
    color BaseColor  = color(.4)
    I'm not sure if the behavior is different using the syntax you have, but you might give it a try.
    In addition, if you use annotations (the anno:: syntax you see in the DAZ provided MDL shaders), Shader Mixer will "do the right thing" when you wire it up.
    edited August 2017
    smiley
