Malformed models
I opened my Daz3D studio this evening to find all the fgures warped into angular charicatures. I've tried simply colsing and reopening, changing viewports but without success , It's probably something simple but I'm no expert with Daz #D or computers in general for that matter.  Help?
  • SanebobSanebob Posts: 0
    What assets are you using?   I see FN Anna, but what clothes?  I assume the "genesis 9" character is the male.  Everything else looks ok scene wise.  The fit of the clothes stands out to me, and maybe the pose(where is the females right arm?)(the males shoes look like one of the maps is wrong/missing).  If you can post a list of the assets so people with those assets can try them out, maybe thatll help.
  • ratadanratadan Posts: 10
    edited March 14
    The other figure is AFN Unrivalled but it affects all models, saved and new. Attached is an example of FI Cairo HD created by but completely unchanged by me. When I go to Parameters/Morphs it shows zero morphs. I have tried using DIM to uninstall and then re-install Daz studio but to no effect. In the second attached image to female character's breasts have swollen to extreme and the features on the faces distorted with big cheeks and lips into grotesque figures. It's not the clothes, it's the figures.
    3440 x 1392 - 1M
    3440 x 1392 - 4M
    Post edited by ratadan on
  • GhostofMacbethGhostofMacbeth Posts: 1,764
    I think that there is a new character that you have to uninstall. Click on the parameters and look under currently used. I think that looks like it might be the new Saga character that is a premier entry from Daz. They are probably working on a fix.
    edited March 14
    Thank you, you are correct. It seems that uninstalling Sigrid and add on is making a difference. Faces are returning to normal but bodies are still grossly muscular hulks.
    What else are you seeing in the currently used?
  • felisfelis Posts: 6,157
    If you are Premier and have installed Sigrids exclussive add-on, you should uninstall her. Have been reported creating this issue.
    Thanks, I have done so but still no change to the bodies. I also tried uninstalling and reinstalling the Genesis Nine stuff but that didn't help. I have a ticket open with them for which I had an initial reply but nothing since, presumable they are closed for the weekend. (deeply frustrating)>
    Despite uninstalling Sigrid she's still appearing in the Currently Used as a body and head shape. There appears to be random other body parts there, also larger than normal.
  • LeanaLeana Posts: 12,995
    The product with the problem is not Sigrid herself, it's the Saga premier exclusive character for her
  • I'm so glad this problem has been identified. I'm never downloading Saga again, though. Pretty face, but that body needed massive modification anyway and having it show up on absolutely every character? Nightmare fuel.
    Having uninstalled Sigrid and her component parts I can now 'repair' my saves. New figures are still malformed and I don't seem to be completely remove Sigrid and her effects but at least I can repair and move on. Here's hoping Daz comes up with a solution soon.
    When you first load a new Genesis 9 figure please go to currently used and see what morphs are listed. You said that new figures are still malformed and that shouldn't be the case. There is a morph that is loading when it shouldn't be.
    I didn't remove Sigrid, just Saga. She's where the problem is. If you don't uninstall her, the malformations will stay in place, but Sigrid can stay. The only ones in this boat are Premier members, because nobody else had access to Saga. I remain astonished that nobody realized what kind of mess they were about to unleash on us.
  • Richard HaseltineRichard Haseltine Posts: 109,556
    Curently Used shows non-default values, the problem is that this is loading with a non-zero default.
    Hmm, interesting. I didn't know that.
