How do I fix a database error?
Drogo Nazhur
in The Commons
I am getting the following error when I try to load a previously saved scene which was working properly ...
2026-03-03 20:18:23.411 [WARNING] :: ..\..\..\..\..\src\dzpostgresqlobjectdatabase.cpp(37): db insert error: ERROR: invalid page in block 4284 of relation base/16384/16873
... I tried deleting the package and re-installing it both through DIM and manually. The problem is still happening. I even restarted my PC.
Some ideas how to fix this:
https://www.disk91.com/2023/technology/systems/fix-postgresql-data-corruption-invalid-page-in-block-of-relation-base-16384/
You need pgAdmin to perform this.
Does this prevent you from opening the scene? If not, ignore it.
Otherwise I recommend to use the CMS Maintenance and backup user data, then reinitiate the CMS and reimport metadata,
Some props are not properly displaying ...
What exactly is CMS? Is there a link to describe how to do what you said? I have over two hundred pages of purchased props
