Medieval Village Construction Kit Memory Problem
Widdershins Studio
Ref: https://www.daz3d.com/medieval-village-construction-kit
I bought this recently and love the models.
I am having a problem with rendering more than a couple of houses in one scene. Is this to be expected?
What I was hoping to do was have several in one scene to create the feel of a village - which I think was the idea behind this asset.
I used GPU-Z to see the memory use. I found that three of the presets will not render.
I have a nvidia rtx 4070 super (12GB).
Anything I can do?
Thanks.
I just ran some render tests on my p40(24GB) and those building presets are coming in at 5-19GB of total vram uage at render.
Unfortunately, this is normal with these kinds of sets. They use a lot of individual pieces instead of a single construct, so you wind up with way more polygons and surfaces than might otherwise be required for a similar building..
About the only thing you can do, is to remove unused items and/or reduce texture sizes.
You can try exporting and reimporting the preset as a single OBJ, but that might not wind up saving all that much vram.
I have a 32 GB card and it was using nearly 60% of memory with three buildings loaded, dropped back to under a quarter when I closed the render window - so that was about a third of 32 GB for three buildings. Running out on a 12 GB card sounds about right.
I stopped buying his stuff as too heavy
not so much a criticism as a sad fact of my hardware shortcomings
Hmm, yeah - would have helped if there was some extra information about resources needed to actually do anything useful with it.
Thanks for the comments.
Does anyone think this may help: https://www.daz3d.com/scene-optimizer
I am keen to use them since I bought them, otherwise I just wasted my money.
Reducing texture size with Scene optimizer will indeed reduce the VRAM used. If you have it, Instancify might also help reducing the number of polygons if there are objects reused several times.
Removing parts which are not visible would also reduce the load.
Thanks for the tip :)
Something is not adding up - I can load and render Stonemason's: https://www.daz3d.com/the-streets-of-the-medieval
Scene Info panel tells me there are about 1 million faces in his whole village scene. GPU RAM usage goes to about 6000MB and it renders after a few seconds.
Going back to the problem individual models above, one of the larger ones on its own will not render at all. It has a similar number of faces, but chokes at the amount of RAM used and then dies.
So does this point to textures being too large in the Construction Kit?
Also, I tried Decimator on the large model I just mentioned. I reduced it to 10%, but in Scene Info it still says there are around 1 million faces.
Confused.
Textures would be the obvious suspect. Stonemason is very good at optimising his models, though, so I would expect them to be much more tolerant than almost anything else.
I wonder if it's the subdivision being used for displacement?, the promos mention 6 levels of subdivision, that means a 100 poly model would become 400,000 polys..switching off sub-d might help?
I can't see how to do that.
There is no Subdivision setting.
BTW in Decimator the big preset that will not render had over 2 million polygons.
For Displacement you must look in the Surfaces settings, close to the buttom you have displacement. If it is activated there will be new parameters that include subdivision.
This is all there is, filtered.
I found other parts with displacement maps, but all are already set to 0 strength.
May I ask why you didn't select all surfaces?
Before you spend any more money, try the free script here to reduce texture sizes. Everyone here is always trying to get people to spend more money, meanwhile the forums are filled with free alternatives.
https://www.daz3d.com/forums/discussion/137161/reduce-texture-sizes-easily-with-this-script/p1
I wanted to show the individual one. I can select All and it shows there are 31 Displacment Strengths - and they all seem to be the same.
Thanks, will give that a go!
Some parts do have SubD, though mostly only two levels. If you put the Viewport in a Drawstyle that shows the emsh lines (e.g. Wire Shaded) The the elements with SubD will have thin lines (the vrtual polygons) between thick (the actual edges in the mesh).
I tried - but it does not appear to have subdivisions? See image.
I can see there are many polys though - is there a reason to use mutliple polys on a single flat surface for example?
I tried the script - selected all the nodes in the scene and clicked exectute. I still cannot render the largest model.
I have almost been tempted to buy this so many times because it looks awesome
in spite of my reservations
thankyou Widdershins Studio for your thread and reality check
I do have the Notre Dame sets by this PA in my wishlist but unless its a killer deal, will likely stay there unless I have a Xlotto win and get a dream PC built
not even wishlisting this one
again, an awesome looking set but not for my potato desktop
Glad it's helped in some way!
That part doesn't have any faint edge lines, so isn't SubDed. Here only the foundation stones apear to have SubD, which is MVCK 2.5m Large Stone 5-Block Set (Front)
There are other foundation stone nodes around the building, though, and there may be other elements not visible here with SubD applied
OK, so it looks like I will have to put this down as a waste of money.
What a shame, it looked so good.
You said you bought it recently, if it was less than 30 days ago you can ask for a refund if you decide you don't want to spend more time trying to get it to work.
Yes, might do that.
One thing... Richard, do you have Decimator?
I was wondering if this works for you - if you select all and reduce to say 10% - does it take up less space for the render?
