Using dformers on specific faces
I read some time ago about someone wanting to move some specific faces on a head. The idea was that you could create a group of just those faces and apply the dformer. The dformer would then only show the hightlighted vertices in that specific group on the head. This was some time ago, I did not bookmark it or "absorb" the info when I read it. Has anyone heard of this and how do I do it?
That sounds like you mean using the Weight Map mode with a D-Former. If that's the case, you can just change Influence Mode to Weight Map. Paint the weight with Node Weight Brush tool, then manipulate the D-Former handler.
As I recal there was nothing about weight maps and more like making a group. Kicking myself for not copying the method.
You're selecting parts of the mesh either way. I think Crosswind's suggestion of using the weight map tool allows for softer edges (instead of a hard in-the-group/not-in-the-group boundary) and less chance of messing up the original mesh.
