Genesis 2 and 3 are darkly tanned in 3 Delight
I got a new Nvidia card and render times in IRAY do not allow me to use IRAY. 3Delight renders are faster than before so I use it. My problem is that with 3Delight my Genesis 2 and 3 figures look like they have been in the sun way way too long. The skin tone in the render looks dark even when DAZ figure is lighter. I hope there is a render setting to help and that I am not the first to have this issue.
I am not very techy, so please be explicit with directions, Thank you,
  • scorpioscorpio Posts: 8,533
    What lighting are you using?
    Are you using 3Delight mats?
  • frank0314frank0314 Posts: 14,713
    If your not using Iray for your renders and have the GPU selected then your GPU won't be used during rendering. Rendering with 3DL only uses your CPU. It sounds like you are having a lighting problem. How may and what type of lights do you have in the scene?
  • kbritkbrit Posts: 8
    I use mainly distant lights and spotlights.
    I dont know what a GPU is.
    And sorry I dont know what you mean by 3Delight mats? or how to use or not use them?
  • AJ2112AJ2112 Posts: 1,417
    Gpu is graphics processing unit - Video card
