any pasties avaliable for a female?
I have wanted to do a stage show image where girls are on stage wearng nothing but pasties to cover their ...um...woman bits :D including below the waist. I have been looking around for something like this for V4 or Genesis or anything but not been able to find a pasties "clothing" thing. Does anyone know is there is anything like this for purchase anywhere for free? I actually have the ones for their chests but not for one in their lower body area which would just be a piece of tape or something.
«1
  • A little ornate but how about:
    http://www.daz3d.com/mystic-giselle-6
    Gotta say i have never seen any in real life other than for the chest. In the U.S. it's usually a thong or nothing depending on the club
    You might try SynfulMindz
  • IceCrMnIceCrMn Posts: 2,333
    there's also the c-string at rendo (freebie)
    https://www.renderosity.com/mod/freestuff/?item_id=63287
    The alphakini is also a good one :)
    http://www.daz3d.com/alphakini-contemporary
  • It's true some of the girls are a bit skinny, giving them pasties might be a good idea.
  • DrekkanDrekkan Posts: 460
    thankkksssss all :)
    http://allrecipes.com/recipe/46981/pasties-ii/
  • bytescapesbytescapes Posts: 1,932
    Now I want to see a render showing a DAZ female figure wearing @Richard_Haseltine's idea of pasties as if they were @Drekkan's idea of pasties ... but it would probably violate the forum ToS.
    Pretty3D's After School for Genesis and V4 has some pasties (non-Cornish variety). But on re-reading I see that @Drekkan was actually looking not for nipple coverings but for something to cover the lower parts of the female anatomy. Wouldn't that be a G-string? (Although I do have a friend who's a celebrated burlesque artist, who wears pasties with tassles on her, uh, posterior: apparently they're called "assles" in the trade).
    Anyway, if you are looking for a thong or G-string, there's probably no shortage of minimal underthings available in the DAZ Store. I'd suggest again that you try Pretty3D's store for underwear that ... well, let's just say that it can be modeled using a very limited number of polygons.
    In these parts (hill country)...those type of undergarments are called 'why bothers'...
  • SlimerJSpudSlimerJSpud Posts: 1,456
    edited November 2015
    "Rub pasties with a little milk for a golden color." surprise ???!!!???
    And not to be completely off topic, there is the Marilee Gear set on rendo.
    Post edited by SlimerJSpud on
  • Oso3DOso3D Posts: 15,116
    I'll note that at least for the top, pasties would be incredibly easy to do as a geoshell. I mean, just two disks, blur them a bit for displacement map, bam.
  • pwiecekpwiecek Posts: 1,598
    I have quite a few. Usually they are included in some other product with a totally deceptive name and usually at the other store.
    Here is a picture of my wishlist.
    Any of these may be no longer available
    You can search for them here
        http://www.whatever3d.com/
    585 x 356 - 57K
    Post edited by pwiecek on
  • Most traditional cornish pasties start off as meat and end up as apple pie I believe depending which end you eat first, top or bottom cheeky
    showgirl pasties need tassles
  • JOdelJOdel Posts: 6,322
    For Poser users Surreality has a whole series of body jewels in the RDNA sale right now. Unfortunately it's flagged as being only for Poser.
    They're beautiful. Just about all of Surreality's stuff is.
    I never knew whether to entirely believe the story that the 'classic' pasty should have one end filled with meat, the other with jam (or apple), so that the Cornish tin miner (presumed consumer of said pasties) could have both his main course and his 'sweet'. Such things certainly existed, but I strongly suspect that your typical tin miner was not so lucky and that the pasty contained whatever there happened to be in the house -- most likely a relatively small amount of meat and a lot of root vegetables.
    The idea that the thick ridged part of the pastry served as a kind of handle that could be used to hold it with and then thrown away (because it would be covered with dirt from the miner's hands) makes more sense, though.
    Not sure why women would use them for hiding their nipples, though, but perhaps I'm getting a little mixed up here.
  • nicsttnicstt Posts: 11,715
    laugh
    Maybe it's the sort of establishment that deals in edible  er biodegradable clothes.
    Post edited by nicstt on
    Apparently each miner would have his initials on the pastie on the meat end, and the fruit end would be glazed, the meat end not glazed, so they didn't eat their pudding before their dinner
    And yes meat and 2 or more veg in the savoury end, usually apple in the other end.  Most miners had a patch to grow things in by their houses.
    Post edited by Chohole on
    If you time it right and get them out of the oven first thing in the morning before getting dressed, they might keep you warm till you got to the bus.
  • XaatXuunXaatXuun Posts: 880
    LilFlame & NemesisT's Purr Lingerie
    can be found either at Renderotic or Renderosity
    Post edited by XaatXuun on
    I think the OP wants pasties with or without tassels for the breasts and some kind of similar stick-on cover for the lower parts WITHOUT the strings to hold it on. Again, there are several things that seem to fit the bill, all of them advertised as something different.
    http://www.daz3d.com/glamorous-aiko-set-for-aiko-3
    There is something called the I Back Panty here:
    http://team-lock-on.com/zoc/
    I also recall that one of the skimp wear fantasy sets had something like this but I can't find it now.
  • riftwitchriftwitch Posts: 1,439
    The top from this outfit (http://www.daz3d.com/heroine-fantasy-armour) could work, if you can make the opacity zero on the chains. I've used the top from this outfit )http://www.daz3d.com/fantasy-assassins-for-v4) for pasties; it was easy to turn down the opacity on the unwanted areas.
  • ByrdieByrdie Posts: 1,783
    I use these: https://www.renderosity.com/mod/bcs/sexy-skinz---body-jewels/107052/
    https://www.renderosity.com/mod/bcs/sexy-skinz---body-jewels-02/110124/
    They work in both Poser and Daz Studio on any figure with V4 mapping. Best thing is, you don't need to worry about fitting them to whichever morphs you've dialled --  heck they even work on my modded Michael whenever I need to put an alien dancing boy in a tavern. devil
  • Ken OBanionKen OBanion Posts: 1,456
    I've always called them 'fanny-floss'.
  • mtl1mtl1 Posts: 1,508
    I believe there's actually one with tassles at Digital Creations as a freebie.
    ... And no, I don't know why I remembered this all of a sudden.
    *jumps out of the thread*
    Post edited by mtl1 on
  • FollyFolly Posts: 13
    If you use Iray, it's a fairly easy process to turn simple images into pasties using decals. A google image search for clip art will turn up lots of images you can use. The same technique also yields some good looking tattoos.
    need some manbewb pasties, with posable tassels
  • XyetztXyetzt Posts: 27,546
    Evil innocence has one in their club for V4 if I recall correctly but it does not include a thing to my knowledge.
