Dogs at Play Poses and Props
Ron KnightsRon Knights Posts: 2,470
edited February 9 in The Commons
**** Edited to add: This is about the Dogs at Play Poses & Props ****
I'm just getting started with this set. It looks great. But I do have a couple questions.
How fo the Hierarchical poses work?!
I see we have "wearable props," in addition to regualar props? How do we make the wearable prop work properly?
An example would be the pet ball. I've seen one pose that has the Dachshund balancing the ball on its head. I attempted to do this manually, but it's probably not accurate.
Another dumb question: is there a way to neuter the male dogs?
Thanks in advance for your help.
Post edited by Ron Knights on
  • felisfelis Posts: 6,134
    Don't know which product you are talking about.
    But for wearables props (for the dog) you must have the dog selected in the Scene tab, when clicking the wearable, andf the prolp should then be parented and positioned at the "right" spot. It may needs readjustment, if the dog you are using is different from what it was intended.
    For hieraical poses, e.g. a prop must be parented to the dog, and they will then both get posed.
  • ElorElor Posts: 3,584
    I think it's this product:
    https://www.daz3d.com/dogs-at-play-props-and-poses
    One of the promo renders explain where to parent the props to make the hierarchical poses work.
  • Ron KnightsRon Knights Posts: 2,470
    edited February 9
    fells, thanks for the info.
    Yes, the product is the Dogs at Play. That's why I included the name in the title.
    smiley
    I never noticed the instructions in the promo. I was already sold on the product.
    705 x 874 - 174K
  • MelanieLMelanieL Posts: 7,811
    There should be a "female" morph for the dog, if that's what you want. Its a body morph so may appear under "body" in the parameters list (I can't remember) or click on the "Actor" level of parameters and search for Female.
    MelanieL, yeah I finally found the female morph after I'd neutered all the dogs.
    So now I have neutered males and "plain old" female dogs.
