G9 skins on G8.1?
in The Commons
Can anyone recommend a utility for putting a G9 skin on a G8.1?
I tried searching and came up blank, but possibly I'm looking wrong (or the store search function just hates me today).
TIA
https://www.daz3d.com/genesis-9-uvs-for-genesis-8-and-81-female
There isn't a male equivalent as far as I know from this vendor.
Nuts. The male version was what I needed.
Thank you, though. At least I know I wasn't just utterly failing at finding it.
I feel your pain. :)
Well, you can make it with the way of using G9 as a Material Suit on G8M.
Here's a full tutorial: https://www.daz3d.com/forums/discussion/comment/9316161/#Comment_9316161
And a full video tutorial if needed : https://mega.nz/file/XexUzYAL#LAM74H8iQ_qWK_dLo1Q35QrRYRTxAm8TYn5xxQYG0mE
Hmm. I haven't tried it (I'm not a big fan of PBR skins), but since most G9 characters, male or female, use the same UVs, could you swap the UVs on your G8M figure for the ones for G8F using Sloshworks' G8 UV Swap https://www.daz3d.com/genesis-8-uv-swap-male-and-female-base and then apply Cayman's geografts to that?
With Cayman Studio's product, UV Sets on all surfaces of G8F as well as geo-grafts need to be G9's UV so it has nothing to do with existing G8's UV ~~ Besides, the geometry of G8M is different from G8F, so Cayman Studio's G9 UV geo-graft for G8F doesn't work on a G8M.
An alternative: turn a G8F into G8M by transferring G8M's morphs with a Clone but fitting wearables may be cumbersome ~~
